Joined
So it looks like our StarGazer has a 2nd recall on the a damaged right hand engine oil separator. Says it may leak and that they just issued the recall on the 25th of this month. Be on the Look out.
Mar 25,2022
Manufacturer Recall Number22S21
NHTSA Recall Number22V191
Recall StatusRecall Incomplete
SummaryON YOUR VEHICLE, IT MAY BE POSSIBLE YOUR ENGINES RIGHT-HAND OIL SEPARATOR WAS DAMAGED PRIOR TO BEING INSTALLED.
Safety RiskA DAMAGED RIGHT-HAND ENGINE OIL SEPARATOR MAY LEAK OIL. IF AN OIL LEAK OCCURS, YOU MAY SMELL OR SEE OIL SMOKE EMANATING FROM THE UNDER-HOOD AREA OR OBSERVE OIL LEAKS ON OR UNDER THE ENGINE. IN SOME CASES, IF SUFFICIENT OIL ACCUMULATES AND MIGRATES TO AN IGNITION SOURCE, AN UNDER-HOOD FIRE MAY OCCUR INCREASING THE RISK OF INJURY.
RemedyFORD MOTOR COMPANY HAS AUTHORIZED YOUR DEALER TO INSPECT THE RIGHT-HAND ENGINE OIL SEPARATOR FOR DAMAGE AND OR OIL LEAKS AND IF FOUND, REPLACE THE RIGHT-HAND ENGINE OIL SEPARATOR FREE OF CHARGE PARTS AND LABOR.
Manufacturer's NotesTO CHECK FOR NON-SAFETY-RELATED PROGRAMS APPLICABLE TO YOUR VEHICLE, SEE HTTP://WWW.FORD.COM/ OR CALL YOUR FORD DEALER.
Mar 25,2022
